Use this procedure to enable Dynamic Nickname Assignment and specify a nickname allocation range.
![Note](images/note.png)
You must disable Dynamic Nickname Assignment before you can change the nickname allocation range.
- Select SPBM.
- Select the Globals tab.
- To enable the nickname server, select enable for NicknameServerEnable.
- In NicknameServerPrefix, type a prefix.
- Select Apply.
Use the data in the following table to use the Globals tab.
Name |
Description |
GlobalEnable |
Enables or disables SPBM globally. The default is disabled. To ensure proper cleanup of MAC tables after you disable SPBM, save the configuration, and then reboot the switch. |
GlobalEtherType |
Specifies the global ethertype value as 0x8100 or 0x88a8. The default value is 0x8100. |
NicknameServerEnable |
Enables or disables the nickname server. The default is disabled. |
NicknameDynamicAllocationStatus |
Displays the Dynamic Nickname Allocation service operational status. |
NicknameServerPrefix |
Specifies the nickname server allocation prefix. x.xx.xx uses the form X.X0.00 from 0.00.00 to F.F0.00. A group, X.X0.00 to X.XF.FF, can provide up to 4,096 nicknames. The default is A.00.00. |
